Hello All, I have uVision 4 and a FRDM-KL05Z evaluation board. At the moment I am programming the flash by copying and pasting the .S19 file to the FRDM-KL05Z Drive.
When I try to use the Download button in the IDE I get the following message:
Error: Flash Download failed - Target DLL has been cancelled.
The only way I have of connecting the board is via USB cable. The board has Open SDA and device manager shows a Com port when the board is plugged in.
Does anyone know what settings I need to make to get dowload and debugging to work?
Thanks in advance Dan
Does Keil support OpenSDA in it's debugging options?
If not, perhaps segger.com/opensda.html
Or ask Freescale
Thanks for the tip. I went to Segger and downloaded and installed their J-Link OpenSDA. Followed instructions and downloaded and installed new firmware. Cycled power. New device detected. Searched for and found drivers.
After a few false starts and more errors, I changed the right setting and it works!
Thank You!
