IAP Simulation using Keil
Hi All,
I am working with P89CV51RD2. I have written a small custom bootloader code that is erasing a Block.
I dump my code at an address starting from 0xF000. And want to erase block 1.
I want to simulate it using Keil. But problem while debugging is, when I am calling PGM_MTP (which is at the address of 0xFFF0) it showing NOP like.,
C:0xFFF0 00 NOP
I don't whether I can do simulation of IAP using Keil or not?
If I can then how can I found internal boot program that can erase section as per command?
One more thing I also tried to Set ENBOOT bit( using AUXR1 register) but still finding NOP at 0xFFF0H address.
Please guide.
Regards,
Utsavi Bharuchwala
  • I know the simulator can't simulate IAP for a number of different processors so it's likely it can't for your processor too.
    Not sure if it might be possible/meaningful to have the IAP code try to raise some signal to trig the simulator script and possibly perform some memory updates in the simulator script.
  • Assume there are many situations where the simulator just isn't going to cut it, and that you need to run code on real hardware, and provide yourself with enough diagnostic output and control that you can experiment.
    For chips you can't ICE, use a UART and write a monitor application that you can interact with.
  • Hi Pier,
    Thanks for reply. Yes As per discussion, I have to test using real Hardware. But it would be great if I can simulate IAP using Keil, that create less time consumption.
    Regards,
    Utsavi Bharuchwala
  • Hi Westermark,
    Thanks for quick reply and guidance.
    Regards,
    Utsavi Bharuchwala
  • But it would be great if I can simulate IAP using Keil, that create less time consumption.
    actually, the opposite is, quite often true
  • I learned to write code in an era when it was very time consuming to write/erase EPROMs, or had to use costly OTP devices. And an ICE cost as much as a new car.
    You learned to understand the flow of your own code in your head, and be very sure it was as error free as possible, without having to single-step it to grasp how it actually functioned. And provide enough interactivity that you could test as much as possible during each cycle.
    It was also a time where manuals were printed and you had to read and interpret them thoroughly, by yourself.
  • Hi Westonsupermare Pier,
    Thanks for reply.
    I go through your suggestions. I start to Test my bootloader using Real Hardware.
    I am using P89C51RD2 in which PGM_MTP is at FFF0H. I call it for erasing Block 2.
    For that I write like, MOV DPH,#40H
    MOV DPL,#00H
    MOV DPH,R2 ;; Erase 8K block
    MOV R0,#24 ;; OSC Freq (integer) in 24.576 Mhz.
    MOV R1,#01 ;; Func code to erase block..
    LCALL PGM_MTP ;; Call boot loader routine to perform..
    But on call of PGM_MTP, program reset all time. I don't know why this is happening?
    Program is not coming below this LCALL PGM_MTP.
    Any suggestions?
    Regards,
    Utsavi Bharuchwala
