I'm trying to install the evaluation version of Keil uVision 5.14.0.0. After the the main installation completes it launches the pack installer. Then I see a message says a download failed with the reason "Security Problem". There are several of these generated installing the pack from Nordic Semiconductor(nRF51?). I can continue past these. Then it has the same problem with TeaxasInstruments.MSP432.psdc. If I continue the installation I see the message "PDSC file update incomplete: Download of one or more files failed".
I am just getting started with Keil after taking an online class on embedded systems using the TI TM4C123G eval kit. I'm not sure what either of these packs are used for. I need to know if I should ignore these errors, or if the packs contain essential components that will cause me problems later?
I have tried reinstalling after disabling my antivirus (Norton), but I got the same results. I'd appreciate any help you can give me to get Keil to install correctly.
Terry
Hi Terry, an alternative solution is to manually download the software pack from : http://www.keil.com/dd2/pack/ and then import it to the Pack Installer using: File -> Import
Does that work?
Kind regards, Ralf
R.Kopsch Senior Applications Engineer ARM Germany GmbH
Each of the Software Packs that you are trying to download contain support for specific devices (either device support directly, libraries, or example projects).
If you start evaluating, we recommend that you download only the Software Packs for the relevant device.
To identify relevant Software Packs, open the Pack Installer and select in the Devices tab the device or device family that you are indenting to use.
In the Packs tab you can then see the relevant software packs along with a description of the content. You should consider if you really need a specific software pack (i.e. lwIP). When more packs are installed also more software components are shown in the MDK RTE window. At some point this might get confusing.
Just another information: it is currently impossible to download 3rd party software packs from http://www.keil.com/pack. For this you must use the Pack Installer.
However, we are not able to replicate the original problem Security Error. Where is this displayed. Is there a pop-up from a anti-virus utility that shows that?
Thanks for the help. The page you linked does not seem to have a download link to any of the Nordic packs or to the TI MSP432. I was able to find a download from Nordic, but from the other comments it doesn't look like I need it to run the Teva TM4C.
It sounds like I don't need any of this. I was just confused because it seemed to be part of the default install.
Thanks for the explanation.
I ran the install again. After I click finish at the end of the install it automatically brought up the pack installer. There is a pop up the describes the pack installer. I clicked I think OK to get past that, then it automatically starts installing something. After a few seconds it brings up 15 popups like the one in this screen shot.
i175.photobucket.com/.../KeilPackError_zps0srg588w.png
I did notice this process seemed a lot faster the second time around. I'd guess that if you already have these packs from a previous install the installer would not need to go to the web for the DFP, so you wouldn't see the message.
Did you try going to the website developer.nordicsemi.com/.../ directly to download the PDSC file?
One time, "I got a waited for 20 seconds" dialog warning from the pack installer, and after that, it installed.
You may check to see if you have any firewalls / antivirus programs running that could be interfering with the tools.
i.e. the pack installer is a separate executable from UV4, so sometimes has to be OK'd by virus / malware checkers:
C:\Keil_v5\UV4\PackInstaller.exe
Thanks for that feedback. We are unable to replicate the problem here.
However the reason for the error message is an error of the Windows Urlmon.dll that the Pack Installer is using. The error (below) has never occurred during our testing.
INET_E_SECURITY_PROBLEM 0x800C000E
The error description is: A security problem was encountered, related to one of the following Win32 Error Messages:
ERROR_INTERNET_CHG_POST_IS_NON_SECURE (12042) ERROR_INTERNET_CLIENT_AUTH_CERT_NEEDED (12044) ERROR_INTERNET_CLIENT_AUTH_NOT_SETUP (12046) ERROR_INTERNET_FORTEZZA_LOGIN_NEEDED (12054) ERROR_INTERNET_INVALID_CA (12045) ERROR_INTERNET_MIXED_SECURITY (12041) ERROR_INTERNET_POST_IS_NON_SECURE (12043) ERROR_INTERNET_SEC_CERT_CN_INVALID (12038) ERROR_INTERNET_SEC_CERT_DATE_INVALID (12037) ERROR_INTERNET_SEC_CERT_REV_FAILED (12057) ERROR_INTERNET_SEC_CERT_REVOKED (12170)
Link with more description: msdn.microsoft.com/.../ms775145(v=vs.85).aspx
I was able to download the Nordic driver pack, and the PSDC. Some else commented that I shouldn't install components unless I am using that manufacturers processor, so I didn't install it. Are you saying that you think I need it if I'm currently using the TM4C123G?
I did try disabling my antivirus to do the install. It didn't make any difference.
Sorry, I did not really answer your question:
No you do not need the NordicSemiconductor software packs for the TI device.
Keil seems to be working, at least to the point that I can create a project.
I'm running 64 bit Windows 7 Home Premium, with the current patches on an i7-3770 CPU, and Norton Security Suite. I haven't changed security setting from what Norton recommended.
If I can provide any more information to help you replicate the issue let me know.
