Hi, I am using MCB2300 kit(lpc2368).Willing to send data through Ethernet. I found few codes and when compiled in uvision 4 , its giving code limited error as it is evaluation version.Are any light weight TCP/IP stacks available through which basic Ethernet configuration with MCB2300 can be done and send data without size limitation error. Thanks in advance. Maya
