My source files are structured in multiple folders, some are in sub-folders. For example: /Source_Files /Source_Files/Algorithm1 /Source_Files/Algorithm1/Filter /Source_Files/Algorithm1/Transform
I would like the Project view in uVision to reflect the directory structure.
Unfortunately, it doesn't appear that I can add a Group under another Group.
Has anyone tried to do something similar?
Thanks.
Chris; I don't think you can do that from the uV4 IDE. You know the group/file structure are just entries in the .uproj file in html format and the .dpt file. They are not really group folders, just html entries. Too bad the icons imply folders in the sense we have come to expect.
I have attempted to play with the .uproj file just to see if I could put a full path name in the file. I could for only one attempt and then the entries are overwritten. I never went further to see if I could circumvent the over write. I just went along with the way the tools are made.
Maybe this is the reason that Keil built the multiple workspace format. So you can build different workspaces with different groups and files. That is, a few different files and many common files in different workspaces.
IAR supports the multiple group folders and files within files within folders within files. Man what a pain to work with. INMHO!
I guess this is the reason that many Keil users prefer a different IDE. Look at the Notepad++. This tool has a Project window that you can configure to your needs. It's found at http://notepad-plus-plus.org. A GNU license product.
Bradford
Bradford,
I am sick and tired or uv4 crashing on me so often when I switch projects (particularly if they contain many files). Also, the common problems with display of automatic variables stored on the stack have not been resolved (despite me providing Keil with at least one sample demonstrating the problem). AFAIK there is no open-source environment that allows debugging with ULINK products available - am I wrong...?
No - you can't.
uVision's whole project model is pretty simplistic.
Tamir;
Have you looked at Keil's attempt to use Eclipse? I have not yet tried. Just saw several posts and wondered if it was real. I'm not talking about DS tools for Eclipse.
All; I just quickly searched the forum for Eclipse entries. With egg on my face I declared I would post all my successes on building an Eclipse interface and I would hide my failures. You will note I have posted No sucesses. It was/is a very low priority effort on my part. But I remember some other news or articles that mentioned that uVision would have an Eclipse connection. I cannot find that article at the present time.
Yes I remember these articles. But then Mr. Keil himself said on the forum he ain't dumping uv4 in exchange for a plug-in...I doubt the wisdom of that choice, though.
I'm not too found of Eclipse.
But uVision could improve a lot with a changed editor component, and some updating of the project tree. Limited amount of work would likely be needed to make uVision a lot better. But right now, I don't think the IDE gets much love from Keil.
Neither am I.
"uVision could improve a lot with a changed editor component, and some updating of the project tree"
Indeed!
Thanks for all the responses. I didn't think I could add a subgroup, but I thought that I'd ask. A member of our group mentioned that it can be kind of confusing trying to find a file in a large project when the Project Window doesn't match the actual folder structure on your drive.
