Hi, I bought an EPM900 to help me work with the LPC915. It came with three bond-out parts:- LPC9351, 936 and 938. I can't find any docs describing their application in the EPM900. I realise I can probably just look at the data sheets for functionality but what is the difference with the bond-out parts and which subset of parts does each apply to for emulation?
RG
In that case, you could speak direct to Keil Support.
I did ask them already but i asked two questions at once and only got an answer to one. I just wondered if anyone else had been there. I will ask Keil support though.
Cheers
I had a similar problem recently. The information I eventually found was that provided that the bondout chip contained the peripherals of the target device it will work. The early EPM900s only came with a LPC932 bondout chip so I couldn't simulate a LPC935 because the bondout chip did not have an A/D. I could still use it provided I did not need the A/D.
Thanks Julian, that seems logical.
