Cannot program 2 boards with any ULINK2
Hello
I have 2 ULINK2 USB-JTAG Adapters and two MCBSTR9 Keil Boards. The former has a STR12FW44 MCU (Vers.3) and the latter a STR912FAW44 (Vers.4). I cannot program Flash memory in any board using any adapter. Messages I obtain are:
Error: Flash Download failed - ARM966E-S   or
Could not stop ARM device. Please check the JTAG cable.
First I though my project was badly configured, but I have spend some days checking it and I can't find where my error is. I've worked with ULINK and I never had problems to download my code.
Currently I'm using a licensed copy of uVision3 with MDK-ARM Version 3.22a. My configuration settings are:
Device: STR12FW44 or STR12FAW44 (I think it makes no difference).
Read/Only memory areas IROM1 checked (startup) address range: 0x0 - 0x88000
Debug settings: ULINK ARM Debugger. Use reset at startup, Verify Code Download, Download to Flash. ULINK 2 Firmware version is 1.36 and JTAG clock is 1MHz. By the way, ULIN2 is correctly listed as HID in PC hardware settings.
Driver for Flash programming: Update Target before debugging checked. Algorithm: STR91xFxx4 Flash Bank 0 (512K, starting at 0x000000): Erase sectors, Program, Verify and Reset and Run.
Perhaps I gave too much information, but I'm stalled and I don't know what to do. ¿Maybe is Flash corrupted?.
Any help would be appreciated. Thank you.
  • and JTAG clock is 1MHz.
    Did you try set clock to 500 kHz? Some time it could help.
  • Back again to work!
    The fact is that last week I was able to program Bank1 with my code, and the application is running in both boards. But now I must to use Bank 0 (it's a similar application but running http web server) and I cannot download any code, even example code provided by Keil.
    Changing JTAG clock didn't work. Bad luck...
    Hello Martin. Unfortunately, I tried this method and I've tried once again: I get the same message and Full chip Erase failed in the console.
    I expect to receive my old ULINK today. I'll try with it and then I'll post the results.
    Thanks for the help.
    (My mail address, which yesterday was ok, appears now as invalid to the forum. So I change the address)
  • you can erase your entire on-board flash using uv3 (see knowledge base for STR9 on the Keil site). what happens if you start your processor at the default 48 MHz? if you tried to program your device using invalid PLL settings, you may not be able to use JTAG with it.
  • Hello Tamir.
    I've tried to erase full Flash following the instructions linked above by Martin. Is there another way to do that from uVision?
    PLL configuration is the same as in Http Demo example. Master clock is derived from PLL, and it's value is 96MHz. I can change it to 48Mhz, but that would be still derived from PLL. Flash Memory Interface Clock (FMICLK) is RCLK divided by 2. Which in turns is Master clock divided by 2. So, in short:
    fMSTR = fPLL = 96MHz
    RCLK = fMSTR / 2 = 48MHz
    FMICLK = RCLK / 2 = 24MHz
    (now is when I miss my tiny 8051)
    Should I change something in that configuration?. And if the problem was in PLL configuration... doesn't a simpler project as Blinky (who's master clock is 48MHz) should work?
    Thank you.
  • Hello N.P.
    The problem is the CSX (Chip Selcect Mapping) bit.
    You said that application is running from Bank1 that means
    CSX bit is set. If you now want to program Bank0 you need to reset the CSX bit before.
    Best Regards,
    Martin Guenther
  • Thanks Martin. That sounds really reasonable.
    Now I cannot try to change CSX bit (work ended!), but at least I have some hope to mend it next Monday.
    I'll post if that solved my problem.
    Best regards.
  • It works!
    Finally I change CSX bit and I could erase and reprogram my boards.
    You guys have helped me a lot. Thanks to all. I'll do my best to help anyone in this forum if I had the chance.
    Best regards!
