Bread Board and 89c51
HI,
I have made a small program on 89c51 to light an led..the entire setup is made on a breadboard..
but there is no response or proper output.
The same 89c51 is working on my project kit accurately.
what is the issue with bread board and 89c51?
  • the entire setup is made on a breadboard..
    if that is a "solderless breadboard" THROW IT OUT
    any signals with fast risetimes are critical (regardless of 8051 or not), a carefully made breadboard with VERY short connecting wires and proper decoupling MAY work. Just to illustrate: may printed circuits that are not 4 layer have problems too.
  • When designing with a breadboard, it is usually best to design with a chip with PLL so an external crystal can run at a quite low frequency, or to use an internal RC oscillator.
    Then you can usually get quite good function, as long as you do not need high-quality analog sections - for example many bits of precision on ADC.
  • Thanks..i hav got it work ..though not entirely..need to amplify some outputs...
    its like a miracle..it worked today after more than two weeks of failure..
