Ulink no tristate after flash
I use the ulink for flash a XC164CM board.
everything working fine. But now I like to use a pin (P3.7_/BRKIN) of the JTAG Interface for general purpose output.
The problem is, the ULINK don't set the outputpin (JTAG_13) after flashing to high impedance. The internal ULINK-signal U_OE is still '0', so the 74LVC244 outputs are still active.
Disconnection of J1 on the ULINK solve this problem.
Even disconnect and connect the USB cable.
Any solution?
Gerd
