Data from hyper terminal to S1IN
is there any way by which i can send the output of hyper terminal to S1IN(vtreg)?
  • You will either need a PC with two COM ports, or two PCs.
    Connect the COM port used by hypoterminal to the COM port used by the Simulator.
    You will need a crossover cable - check that it's working by using Hypoterminal on both COM ports
  • i want to send data from hyperterminal to UVision2 program, so that it is taken into into S1IN. u r sayin that i use a crossover cable...but wat is the setting in UV2 tat i will hav to do so tat the data is taken into S1IN(after puttin the crosover cable in place)?
  • "u r sayin..."
    Unless you are actually writing this on a mobile phone keypad, or have some disability that impairs your use of the keyboard, you need to write your words in full.
    If it's really too much trouble for you to write "you are saying..." in full, then this is my final answer.
  • Mr.Yash Sing,
    y r u always wastin d 4m webspas by givin l'oborated txt? nsted of
    ...i want to send data from hyperterminal to UVision2 program, so that it is taken into into S1IN. u r sayin that i use a crossover cable...but wat is the setting in UV2 tat i will hav to do so tat the data is taken into S1IN(after puttin the crosover cable in place)?...
    u can write as
    ... i wan 2 sen data frm hy/termnal 2 UVson2 progrm, so tat its takn n2 S1IN.u r sayin tat i use a crosover cable... bt wats d z'tin n UV2 tat i'll hav 2 do so tat d data s takn n2 S1IN(aftr putin d crosover cabl n plas)? ...
    dis vil b ec 4 us 2 read.
  • Mr.Yash Sing,
    u can write as
  • u can write as
    ezr:
    i wan 2 sen d8a frm hyptrm 2 uv2 so tat its takn n2 S1IN. u r sayin tat i use a xover cble... bt wats d z'tin n UV2 tat i'll hav 2 do so tat d d8a s takn n2 S1IN (aftr putin d xover cbl n plas)? ...
    sn tat ezr?
