I am using uVision2 in conjunction with "Texas TAS1020". I use Hitex x51 emulator and the driver (http://www.keil.com/download/docs/119.asp) to debug my program. I would be happy if you could provide me some applications notes or information on how to configure and setup such environment using uVision2 and Hitex X51 so that I can access the TAS1020's onchip ROM functions and its peripherals such as I2C, USB.
My environment is almost working and I can start debugging and communicate with Hitex emulator and go step by step through my source code, but due to some problems I am not able to access the tas1020 onchip peripherals and memory space from within the code running on Tas1020.
Any help regarding memory maps (such as emulator overlay memory, target memory) and troubleshooting their issues is highly appreciated
"My environment is almost working and I can start debugging and communicate with Hitex emulator and go step by step through my source code, but due to some problems I am not able to access the tas1020 onchip peripherals and memory space from within the code running on Tas1020.
i wonder if there is verity in that,
i mean, if the access to hte chip is itself not established, there is no point in assuming the environment is almost working,
PS, had a similar experience, thats why so confident, check it out,
Well, I mean that the program which runs on the emulator is kind of running in an independent mode.
To be more precise I should say that I can access some peripherals such as UART and TIMER (because they reside on the microcontroller on the emulator cable) and I can see the debugging printfs on my PC.
Unfortunately I am not able to call functions from TAS1020's ROM because [I think] the program inside the emultor memory does not see the ROM at address 0x8000 it just reads some garbage data at that address.
I am also not able to communicate with the peripherals on TAS1020 because [I guess] their address space is mapped into emulator overlay memory not to the real target (TAS1020)
Thanks for the help
In that case, why dont you jus try outsourcing your program, thats a better option,
driving Home this point that its a most viable suggestion
find out what the other guys ask for in return,
Is the Emulator Configured / Mapped correctly? Does it have enough memory? Are you using banked memory? If so does the emulator's debugger support it.
MY compiler does it for me;
Plz do give an answer instead of Re-directing to other ,
btw, wats banked memory?
Waiting for reply,
Hello dear friends,
First of all I should say that the message posted on "2-Nov-2006 06:16" which was signed by name "Ali Fakoor" saying "MY compiler does it for me;" was not posted by me!!! (I don't know who has sent it by my name and I kindly request him/her not to repeat this)
Now the answers to your questions:
Is the Emulator Configured / Mapped correctly? I guess this is what makes the problem. I think I have not been able to configure it properly and need help in this section
Does it have enough memory? I think It should have, because I haven't faced any problem regarding memory size (actually the microcontroller I use limit me to 6016 bytes of code)
Are you using banked memory? If so does the emulator's debugger support it. No I don't use baked memory.
wats banked memory? This is a technique to overcome code-segment size limitations of 64KB. This means that you can use multiple banks of external 64KB memories (I think up to 16 banks). By using an external logic you should support switching between them. Your compiler/linker also needs to be aware of/support banking in order to embed some bank switching code libraries.
As discussed, your problem with the Hitex emulator is an issue for the Hitex support.
Dear friends, Thanks for your information and assistance.
Unfortunately Hitex is not providing support of any kind or even any information about the x51 and its combination with uVision any more (because x51 driver for uVision is considered to be out-dated and discontinued product).
I couldn't establish my desired environment in uVision using their x51 driver, but after a simple firmware upgrade I was able to use their Hi-Top 5 environment to load and debug my program in disassembly mode.
Since the ideal case is to both program and debug in uVision2 environment and there is no more information available about using Hitex in an Integrated way with uVision (I mean for TI TAS1020 [with on-chip boot-rom]). I am currently working myself to overcome the issue by some practice and will inform again here in case of success.
