I need to exchange data (AT commands) between 8051 and IrDA enabled cellphones. I have an evaluation board (8051) with an RS-232. I'm looking to find a serial to IrDA converter but I haven't had much luck. Is there any device that can do this the you are aware of? Mass.
microchip
Use the 'Search' on this site - it's been discussed before. Also, look for "SIR" - that's "Serial InfraRed". It basically takes the serial data from a UART and turns it into pulses of IR. http://www.irda.org/ Vishay also make suitable devices.
I have used the Microchip MCP2140 (9600 baud) for this. Microchip also makes a higher speed version. Javier
I need to exchange data (AT commands) between 8051 and IrDA enabled cellphones. Can any one through some light on interface standard,format etc... followed to interface IrDA enabled cellophones... Rgds Raj Shetgar
Thanks for the replies. What I'm hoping is to find a device that I can connect to the srial port of the board with a 9 pin connector. Is there any off-the-shelf device built based on microchip in the market?
Infrared PC Adaptor (JetEye PC): http://catalog.blackbox.com/bboxuk/Templates/blackbox/products.asp?param=401&ig_id=2768&title=Infrared+Adaptors+for+PC%2C+Networks%2C+and+Printers
