Mapping externe: Code:EPROM 00000--01FFF Code:RAM 12000--1FFFF Data:RAM 02000--0F6FF External logic manage the A16 line of RAM chip: - A16=1 on falling edge of ALE - A16=0 when RD or WR = 0 My code is stored in 2 I2C eeprom. The Boot code download it in upper RAM (A16 force to 1), then goes in automatic mode described before. Every things seams ok (sumckeck test works...) BUT I have a very strange behaviour: one program (A prog) works and another one (B prog) doesn't work. The only difference between them is local variable of a function. The A prog has int myVar; and the B has int idata myVar; My target is a C505CA from infineon and I use the small model. My internal ramsize is 256. I have check in detail the both M51 file the overlay of memory. It seams to be ok. To be sure that A prog works correctly I need to check two things: 1) my hardware solution 2) why the affectation of idata in local variable generates troubles
There is still a setup time violation, no matter how long the WR pulse is. You cannot expect this to work reliably.
You are still waiting for PSEN, no matter if you latch PSEN or decode it with combinatorial logic. This has no material effect on the timing which will be the sum of: 1) logic (or flip-flop) delay from falling PSEN to A16 2) RAM read delay from address in to data out 3) CPU code fetch setup time 4) trace delays
There is no problem here because it is a read operation, not a write operation. All you have to worry about is meeting the code fetch setup time of the CPU. For the RAM chip there is no setup time requirment from valid address to falling OE. There is no possibility of data corruption during a RD cycle, so the timing is less critical.
to resume: C505CA, 12MHz, RAM 70ns PSEN pulse = 125ns RD or WR pulse = 250ns
-------- 1-------|D Q|------A16ram ALEc505--------o|CLK | | | RD/and WR/c505--|CLR | --------
to resume: C505CA, 12MHz, RAM 70ns PSEN pulse = 125ns RD or WR pulse = 250ns A16=1 -> upper RAM is CODE A16=0 -> lower RAM is DATA Note: Code is written with A16 forced to 1
OE/ram = RD/c505 and PSEN/c505 WE/ram = WR/c505 -------- 1-------|D Q|------A16ram ALEc505--------o|CLK | | | RD/and WR/c505--|CLR | -------- (CLK is falling edge of ALEc505)
If you can delay WE on the RAM chip until after A16 is valid then you will be OK.
New solution:
CLK12MHzsin----|>o---|>o--CLK12MHz ----- ----- ALE----------|D Q|----ALEFF1----|D Q|----ALEFF2 CLK12MHz----o|CLK | ---|CLK | | ----- | ----- |_____________________|
ALEFF1____________ | ----- | PRE | PSEN/---|>o----|D Q|-----A16 ALEFF2--------o|CLK | | | -----
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ CLK12MHz _| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_ ___ ___ ___ ___ ___ ALE _| |_______| |_______| |___________________| |_______| |___ ___ ___ ___ ___ ___ ALEFF1 ___| |_______| |_______| |___________________| |_______| |_ ___ ___ ___ ___ ___ ALEFF2 _____| |_______| |_______| |___________________| |_______| _____ _____ _____________________________ _____ PSEN/ _| |_____| |_____| |_____| |_ ___________________________________ ___________________ RD/ or WR |_____________| _________________________________ _________________ A16 ___| |_________________|
I did not examine your logic, but if it does produce the timing relationships shown in your diagram then this should work.
This might give you better worse case timing.
ALE________________ | ----- | CLR | 1--------------|D Q|-----A16 /PSEN2--------o|CLK | | | -----
Why??? What is /PSEN2 ? timing ?
It was a typing error. /PSEN2 => /PSEN. For a data cycle, A16 is valid right after ALE is asserted. For a code cycle, A16 is valid right after /PSEN is asserted. In this design, "A16 stable" to the "leading edge of /WR" time is from the very beginning of the write cycle. In this design, "A16 stable" to the "micro reads data" time is from the very beginning of the read cycle. In this design, "A16 stable" to the "micro reads program" time is from the very beginning of "/PSEN" strobe.
For me your design is equivalent to:
A16 = not(PSEN/)
