Hi all,
I'm currently in the process of updating the ARM Compiler Embedded from version 6.00u2 to 6.19 and have encountered an issue where the --cpu list is incompatible.We are puzzled as to why the --cpu list does not support the 8-A.32/64 crypto selections, especially since these two options are listed in the official document provided below:developer.arm.com/.../--cpu-name--armasm-
Could you please advise if there is any solution to enable ARM Compiler 6.19 to support 8-A.32/64 crypto?Thank you in advance for your assistance!
Figure. the --cpu=list results of ARM Compiler 6.19
Regards,
BH Liu.
Please see the below link (search for the "Cryptographic Extensions" section).
https://developer.arm.com/documentation/101754/0619/armclang-Reference/armclang-Command-line-Options/-mcpu
Hi Ronan!
Thanks for your immediately reply!Finally, I try to activate the license manually by the command:ARMCompiler6.19/bin/armlm activate --server [server_address] --product [product_code]
https://developer.arm.com/documentation/102516/1-3/Activate-and-deactivate-your-product-license/Activate-your-product-using-a-license-serverAlthough I haven't figured out why the installation procedure initially created a limited license for me, the activate command resolve this issue.
