I just downloaded uVision MDK 5.37 with ArmClang v6.18 for Windows. However, I needed a version of Armcc V5 in order the build some existing example software. I installed Armcc V5.0.6 update 7 (build 960) from the legacy compiler page and added it to the list of available compilers. I am currently on a 30-day professional evaluation license. When I build with the required Armcc compiler I get the following output
Product: ARM Compiler 5.06Component: ARM Compiler 5.06 update 7 (build 960)Tool: ArmCC [4d365d]compiling syscntl.c...Error: C9555E: Failed to check out a license.The license file could not be found. Check that ARMLMD_LICENSE_FILE is set correctly.ARMLMD_LICENSE_FILE is not set. You must set this to the path to your license.Information about this error is available at: ds.arm.com/.../m1 General licensing information is available at: ds.arm.com/.../ If you need further help, provide this complete error report to your supplier or license.support@arm.com. - ARMLMD_LICENSE_FILE: unset - LM_LICENSE_FILE: unset - ARM_TOOL_VARIANT: unset - ARM_PRODUCT_PATH: unset - Product location: C:\Program Files (x86)\ARM_Compiler_5.06u7\sw\mappings - Toolchain location: C:\Program Files (x86)\ARM_Compiler_5.06u7\Bin - Selected tool variant: product - Checkout feature: compiler5 - Feature version: 5.0202006 - Flex error code: -1
Keil is installed at C:\Keil_v5\ but I'm not sure where to find the license file. Do I need to install the Armcc compiler in a different location? Any thoughts would be appreciated.
You need to install the compiler into the MDK install directory. See https://developer.arm.com/documentation/ka005073/latest
Regards, Ronan
