I raised a case by e-mailing the e-mail address mentioned in the error but no reply so far (it was only 3 hours ago). I guess they are busy so seeing if anyone here knows. (It's case 00409473).
I have downloaded Development Studio on my Linux VM. I selected an eval license when DS started up. It complains that “This host does not match the host ID in the license”.
I don’t know what I could have done wrong – the only option was to tie it to the ethernet adapter so I selected that option. I have not even re-booted the VM.
Is it because it’s a VM? I’m using Oracle Virtual Box with Mint 20 which is Ubuntu based. I didn’t install as root because I don’t need the USB drivers. I have tried re-installing as root but that didn't help.
Looking at the link in the error message (http://ds.arm.com/support/lic56/m9) none of the reasons for the failure apply.
The full output from a “hello world” test in DS is as follows:
make all
Building file: ../src/test.cpp
Invoking: Arm C++ Compiler for Embedded 6
armclang --target=aarch64-arm-none-eabi -xc++ -fno-exceptions -O2 -MD -MP -c -o "src/test.o" "../src/test.cpp"
armclang: error: Failed to check out a license.
This host does not match the host ID in the license.
armclang: note:
Information about this error is available at: http://ds.arm.com/support/lic56/m9
General licensing information is available at: http://ds.arm.com/support/licensing/
If you need further help, provide this complete error report to your supplier or license.support@arm.com.
- ARMLMD_LICENSE_FILE: '/home/peter/.arm/ds/licenses:/home/peter/.arm/ds/licenses:/home/peter/.arm/ds/licenses:/home/peter/.arm/ds/licenses:/home/peter/.arm/ds/licenses:/home/peter/.arm/ds/licenses:/home/peter/.arm/ds/licenses:/home/peter/.arm/ds/licenses:/home/peter/.arm/ds/licenses:/home/peter/.arm/ds/licenses'
- LM_LICENSE_FILE: unset
- ARM_PRODUCT_DEF: '/opt/arm/developmentstudio-2021.2/sw/mappings/eval.elmap'
- ARM_PRODUCT_PATH: unset
- ARM_TOOL_VARIANT: unset
- Product location: /opt/arm/developmentstudio-2021.2/sw/mappings
- Toolchain location: /opt/arm/developmentstudio-2021.2/sw/ARMCompiler6.17/bin
- Selected tool variant: product
- Checkout feature: ds_suite_eval
- Feature version: 0.0202110
- Flex error code: -9
Product: Arm Development Studio Evaluation 2021.2
Component: Arm Compiler for Embedded 6.17
Tool: armclang [5e25bf00]
Thanks.
Peter.
Since composing this post, I have had a reply from support who asked for the output of "ifconfig".
Argh - it's because the option you get on starting up the DS IDE for an eval licence only creates a licence the first time - no matter what platform you are on. I had created an eval licence on Windows previously and didn't realise I now have one eval licence across all platforms. I've submitted a re-hosting request.
