The problem of modifying the cache parameter in the Canvas
I want to modify cache latency parameter in system canvas,and I use FVP_Base_Neoverse-N1 to build my system,so is it correct to modify the cache parameters like this?
  • Hi, thanks for the question.  By default, cache modelling is disabled in Fast Models / FVPs.  For the most part the presence - or otherwise - of a cache does not affect software functionality and modelling the caches in a programmer's view model like Fast Models has an impact on the simulation performance.  However, you do need to switch cache modelling on in order simulate cache access and have the timing parameters to take effecy.
    In the Base FVPs such as Neoverse-N1 there is a top level parameter called "cache_state_modelled" that switches on (or off) the modelling of all caches.  Each cache in the platform can be enabled or disabled individually, but generally you would either want all on, or all off.  There are several ways to set this parameter.  I generally use a command line switch when running the FVP: "-C cache_state_modelled=1".
    Another option is to set it in System Canvas and rebuild the platform.  To do this:
    • open the project
    • with the top level LISA file (FVP_Base_Neoverse-N1.lisa) open, click "properties"
    • select the "parameters" tag
    • change the default value of cache_state_modelled to 1
    • save
    • build
    Now when you run the FVP cache modelling will be on by default.  You could then turn it off if needed by adding "-C cache_state_modelled=0" to the command line.
    The second stage of adding delays to the cache transactions in the model.  A Neoverse-N1 has:
    • l1 dcache, l1 icache, l2 cache per core
    • l3 cache shared between all cores
    Each of these has a set of parameters for hit/miss, read/write, snoop and maintenance latency.  The methods for setting them are the same as those for the global cache state modelled paramter.
    • on the command line, add (for example) "-C cluster0.dcache-hit_latency=<value>"
    • edit the value in the LISA by:
    • right click on the Neoverse model (called "cluster0")
    • select "object properties"
    • select "parameters" tab
    • edit the value of all the cache operations that you want to assign a latency
    • (or you could double-click on the "cluster0" model to open the LISA for that model and edit the parameters in the source code)
    • save
    • rebuild
    There is one final step to get these values recognized when you run the FVP.  By default, all latencies are ignored when a fast model runs.  To enable them, you need to set an Environment Variable called FASTSIM_DISABLE_TA.  Set this to "0" for the latencies to applied in the simulation before running the FVP.
    The documentation for Fast Models Timing Annotation can be found here: developer.arm.com/.../timing-annotation.
    Regards,
    Rob.
  • Dear Rob
    Thanks for your answer, I get it!
    Best regards
    qiqi
  • great!   if you have more questions, let me know!
  • Hi Rob
    I have another problem now.
    I set cache_state_modelled=1,dcache-state_modelled=1,icache-state_modelled=1,dcache-hit_latency=0x4,cpu0.l2cache-hit_latency=0x10 in LISA, and build,then I set environment value FASTSIM_DISABLE_TA="0". Then start FVP.
    I use lmbench to test the fixed model on FVP, Lmbench is a miniature assessment tool(link is here: http://www.bitmover.com/lmbench/), and I use lat_mem_rd(memory read latency benchmark) to get mem_load_latency(link is here: http://www.bitmover.com/lmbench/lat_mem_rd.8.html). The memory size of the test is set to 128MB, but the result of mem-load-latency test is always about 10ns, the fixed parameter seems to be not enable.
    The test file is here,the first column is the memory range, and the second column is the mem_load_latency.
    Memsize	latencytime
    0.00049	10.729
    0.00098	10.719
    0.00195	10.719
    0.00293	10.72
    0.00391	10.72
    0.00586	10.72
    0.00781	10.72
    0.00977	10.72
    0.01172	10.72
    0.01367	10.563
    0.01562	10.565
    0.01758	10.566
    0.01953	10.567
    0.02148	10.565
    0.02344	10.567
    0.02539	10.512
    0.02734	10.513
    0.0293	10.516
    0.03125	10.514
    0.03516	10.514
    0.03906	10.487
    0.04297	10.487
    0.04688	10.486
    0.05078	10.472
    0.05469	10.472
    0.05859	10.473
    0.0625	10.462
    0.07031	10.462
    0.07812	10.457
    0.08594	10.45
    0.09375	10.449
    0.10156	10.444
    0.10938	10.445
    0.11719	10.442
    0.125	10.437
    0.14062	10.435
    0.15625	10.434
    0.17188	10.431
    0.1875	10.429
    0.20312	10.428
    0.21875	10.427
    0.23438	10.426
    0.25	10.425
    0.28125	10.423
    0.3125	10.422
    0.34375	10.423
    0.375	10.419
    0.40625	10.419
    0.4375	10.419
    0.46875	10.418
    0.5	10.418
    0.5625	10.417
    0.625	10.416
    0.6875	10.416
    0.75	10.416
    0.8125	10.416
    0.875	10.414
    0.9375	10.413
    1	10.415
    1.125	10.417
    1.25	10.415
    1.375	10.415
    1.5	10.411
    1.625	10.416
    1.75	10.415
    1.875	10.414
    2	10.412
    2.25	10.412
    2.5	10.414
    2.75	10.412
    3	10.411
    3.25	10.415
    3.5	10.413
    3.75	10.411
    4	10.412
    4.5	10.411
    5	10.415
    5.5	10.414
    6	10.412
    6.5	10.414
    7	10.412
    7.5	10.413
    8	10.414
    9	10.413
    10	10.413
    11	10.408
    12	10.41
    13	10.415
    14	10.414
    15	10.411
    16	10.415
    18	10.413
    20	10.413
    22	10.411
    24	10.412
    26	10.411
    28	10.412
    30	10.411
    32	10.414
    36	10.411
    40	10.412
    44	10.412
    48	10.41
    52	10.411
    56	10.411
    60	10.411
    64	10.412
    72	10.409
    80	10.413
    88	10.412
    96	10.41
    104	10.411
    112	10.412
    120	10.412
    128	10.412
  • setting the cache modelling on, and timing annotation on, allows you to annotate estimated delays on cache accesses.  however, adding delay estimates to the memory accesses - which I think is what you are looking for - requires an additional step.
    to annotate delays to the memory access, requires that the memory model be implemented in SystemC and connected to the Fast Model through an AMBA-PV port.  Fast Models uses the time parameter on the b_transports as defined in the TLM 2.0 specifications to annotate the estimated delays.
    You will need to modify the FVP source example you are using to make this possible as within the FVP the memory is currently modelled within the Fast Models subsystem.  This is quite a complex subject: if you would like to continue I think we should move this discussion to our support channel rather than using the forum.
    One other question to ask: does the application code that are running on the FVP configure and enable the caches?  As well as enabling the cache models in the FVP the code itself needs to implement the correct cache setup code before instructions and data are saved in the caches in the model (in the same way that it would need to be set up on a hardware target),
  • Hi Rob
    Thanks a lot and sorry for the late reply. the application code that are running on the FVP don't need to configure the caches. And I have created a case-Adding delay estimates to the memory accesses on Surpport, can we move to there to discuss?
    regards
    qiqi
