DS-5 debugger doesn't work. In Run->Debug Configurationn->DS-5 Debugger-> New Configuration, the button Debug is always in grey, can't be clicked. I tried both floating license and 30-trial license.
The License Manager Diagnostics shows:(30-day trial license)
Product Information: Version: 5.27.1 Build number: 5271024 Build date: 201706 Selected toolkit: DS-5 Ultimate Edition (Evaluation) ARM_TOOL_VARIANT environment variable: ulteval arm.tool.variant system property: ulteval
Licenses are searched for in the following locations: ARMLMD_LICENSE_FILE environment variable: "C:\Users\xxxxxxxx\AppData\Roaming\ARM\DS-5\licenses" LM_LICENSE_FILE environment variable: not set DS-5 licenses directory: "C:\Users\xxxxxxxx\AppData\Roaming\ARM\DS-5\licenses"
License Mapping Information: ARM_PRODUCT_DEF environment variable: not set ARM_PRODUCT_PATH environment variable: "C:\Program Files\DS-5 v5.27.1\sw\mappings" ARM_TOOL_VARIANT environment variable: "ulteval" ARM_CONFIG_PATH environment variable: "C:\Users\xxxxxxx\AppData\Roaming\ARM\DS-5_v5.27.1"
Licenses used recently (Streamline and DS-5 Debugger only): (none)
License checkout log (Streamline and DS-5 Debugger only): (empty)
Anybody knows the reason I can't use Debug? Any configuration wrong or missing?
Hi yyy,
I have moved your question to the Software Tools community as they would be best placed to answer your question.
Ryan
The debugger does not check license validity until you actual make a target connection - it does not drive the enable state of the Debug button.
The more likely issue is that there is a problem with the debug configuration itself. Is there not an error message at the top of the dialog you showed ? My complete guess is that in the Debugger tab, the 'Run control' group is set to something other than 'Connect only'. This means you must supply .axf files in the Files tab so that the debugger can resolve the symbols for the entry point or main. Try setting the Run control to 'Connect only' and see if the Debug button gets enabled.
If it is not this, please post a complete screen shot of the Debug Configurations dialog.
Regards Tony
Please try this:
In Debug Configurations -> Debugger -> Run control, select "Connect only".
Also in Debug Configurations -> Files -> Target Configuration, make sure no files are uploaded.
Click "Apply" and the Debug button should be working.
Let me know if it helps.
Giuseppe.
Thanks for everyone. It is because of the configuration, once I change to "Connect only", the Debug button is active.
