Model Parameters taken: -C cluster0.NUM_CORES=2 -C bp.secure_memory=false
Using the same process, I was able to run the project on A53 and A720. Here it stops and doesn't print anything.
Hi there, thanks for asking a question. I have moved your question to Architectures and Processors where I think that you will have better chances at getting an answer.
Hello Sonu,
I think I have replicated your issue.
Stepping through the init code, I saw it hit on an access to a SIMD q register, which was trapped by CPTR_EL3 TFP bit.
https://developer.arm.com/documentation/101430/0102/Register-descriptions/AArch64-system-registers/CPTR-EL3--Architectural-Feature-Trap-Register--EL3
You should add init code to clear this register (see the supplied example startup_Cortex-A78MPCore_AC6 project), or you can quickly clear this on the debugger register view or command line (or add to your script for disabling semihosting):
set semihosting enabled off set var $AARCH64::$System::$Secure::$CPTR_EL3.TFP = 0
I see that this bit is clear by default on the Cortex-A720 FVP, hence you did not encounter this.
Regards
Ronan
Thanks Ronan,It is working by doing this.
