Adding -DUSE_LLVM_DWARF_PARSER=True to armdbg command not working
I am trying to add symbols from a DWARF 5 elf format. I have added the  -DUSE_LLVM_DWARF_PARSER=True as the very first parameter of the armdbg but still I am getting this error:
add-symbol-file ***/hello_world.elf
ERROR(CMD685-COR11-IMG34):
! Failed to load symbols for "hello_world.elf"
! Failed to read the symbols from  ***/hello_world.elf
! Section .debug_info offset 0x4: DWARF version 5 is not supported. To use the DWARF 5 format, enable the LLVM DWARF parser.
armdbg --version
Arm Debugger [Build 10]
Copyright (C) 2008-2024 Arm Limited (or its affiliates). All rights reserved.
Regards
Amir
  • Hi Amir
    My name is Stephen and I work at Arm.
    It looks like you are using Arm DS 2023.0.  Sorry, but there is a known issue with armdbg in Arm DS 2023.0 where the USE_LLVM_DWARF_PARSER command-line switch doesn't get handled correctly.  This issue is fixed in Arm DS 2023.1.
    Are you able to update to Arm DS 2023.1, or better, to the recently-released Arm DS 2024.0?
    DWARF5 support is now the default in 2024.0, so there is no need to use the USE_LLVM_DWARF_PARSER command-line switch anymore.  If you need to revert back to the legacy parser, there's a new switch "--use-legacy-parser".
    Hope this helps
    Stephen
  • Hi Stephan,
    Thank you for your respone.
    I will ask for 2024 version and meanwhile as a workaround I am using -gdwarf-4 in the make process.
    Regards
    Amir
