ArmDS Editor shows 'red lines' below stdint_t types on Windows
Hi friends,
my colleagues, working with Windows OS, reported a problem with ARM-DS painting 'red lines' under the types from 'stdint_t'. See the following:
I tried to reproduce this problem on Linux (I do not work with Windows anymore...), but I was unable to do so.
My colleagues on Windows use Docker images to build and compile their sources. They do not have a cross compiler installed locally on the work PC. So I suspect, that ARM-DS can't frind any C compiler headers as they are usally found under /usr/include/... on Unix systems.
Their questions is now, how these 'red lines' can be removed.
My first idea is to install a cross compiler as well, or at least the usual files from /usr/include/std*.h. Maybe ARM-DS will then be able to find some definition for the C99 types.
Any other ideas and or better solutions?
Is it possible to configure ARM-DS Eclipse to ignore the C99 type / add them to some dictionary /... ?
Andy help is appreciated.
Best regards
 Carsten
0
