How to change HEX start address for flash
I created a HEX file using IAR with vector table .intvec start = 0x10000000 & ROM start and End with 0x10000000-0x00004FFF
( i.e goto Option>Linker> 1. Vector Table,  2. Memory Regions etc.)
When I try to write the HEX file to the flash memory, I got a error message,
Data file contained an address which was outside the maximum allowable..
How can I change/modify this HEX so that I can write it to flash (start 0x0000)?
Thank you.
