EWARM linker function redefinition problem
In one 'c' file I define the following function:
void fnTemp(int jj, int kk);
     ...do some stuff...
In a different 'c' file I have the following:
extern void fnTemp(int jj);
void fnTryIt(void)
    fnTemp(3);
This will link without any errors. How do I get the linker to tell me that I have two definitions for fnTemp()?
I know that I could put the declaration for fnTemp() in a .h file and include the .h file in both .c files which will then trigger a compiler error. But I have an instance where that can cause other issues.
Thank you for any help.
