Site
Search
User
Site
Search
User
Support forums
Arm Development Studio forum
data & unified cache
Jump...
Cancel
Locked
Locked
Replies
Subscribers
118 subscribers
Views
Users
0 members are here
Options
More actions
Cancel
Related
baskaran chidambaram
over 12 years ago
Note: This was originally posted on 9th March 2013 at
http://forums.arm.com
In the A8 cache registers i see that the data cache tied to Unified cache - for enabling, cleaning etc. Any reason for this?
Regards
Baskaran
over 12 years ago
Note: This was originally posted on 10th March 2013 at
In the documents, the Data and unified cache are affected by single configuration. For eg
"c6 2 Invalidate Data or Unified cache line by Set/Way"
from
http://infocenter.ar...k/Babhejba.html
why there no separate configuration for Unified cache. why it has to be clubbed with Data cache?
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 12 years ago
What do you mean by "tied to"? You can do cache maintenance on the L1 without explicitly impacting the L2 (there will be impacting side effects from any line evictions from the L1 of course).
Cancel
Vote up
0
Vote down
Cancel
Peter Harris
over 12 years ago
Note: This was originally posted on 11th March 2013 at
[color=#222222][font=arial, helvetica, sans-serif][size=2]> why there no separate configuration for Unified cache. why it has to be clubbed with Data cache? [/size][/font][/color]
[color=#222222][font=arial, helvetica, sans-serif][size=2]At a given level in the cache hierarchy you will either have a separate I and D cache, or a unified cache. You never have both a D cache and a unified cache at the same level. [/size][/font][/color]
[color=#222222][font=arial, helvetica, sans-serif][size=2]For 99% of ARM implementations you will have separate I and D at level 1, and a unified level 2. The usage of the set way logic selects which cache level you want to invalidate, so you can target either the D or the U cache depending on what level you have selected.[/size][/font][/color]
[color=#222222][font=arial, helvetica, sans-serif][size=2]You group the I cache by itself because it is fundamentally different to the other two - D and U can both contain modified data, the I cache cannot, so many encodings make no sense for an I cache.[/size][/font][/color]
[color=#222222][font=arial, helvetica, sans-serif][size=2]HTH,
Iso[/size][/font][/color]
Cancel
Vote up
0
Vote down
Cancel
Martin Weidmann
over 12 years ago
That is a probably a question only the senior architects at ARM can answer with certainty.
My suspicion is that it was simple to save space in the encoding. At a given level the cache(s) will either be harvard (separate I & D) or unified. Given that, it seems sensible to save some encoding space by doubling up some of the commands.
Cancel
Vote up
0
Vote down
Cancel
