I'm developing a custom bootloader for NXP i.MX6 DualLite (ARM Cortex A9).
In this bootloader, I need to initialize ~50 MB of RAM to Zeros, this part executes really fast after enabling Caches, MMU and Program Prediction.
What I need is to know is if the following sequence is ok, or if I need to add more step (Like invalidating the caches ... etc.)
1. Enable the Caches, MMU and Program Prediction:
mrc p15, 0, r0, c1, c0, 0 orr r0, r0, #ARM_CTRL_ICACHE orr r0, r0, #ARM_CTRL_DCACHE orr r0, r0, #ARM_FLOW_PREDICT orr r0, r0, #ARM_MMU_ENABLE mcr p15, 0, r0, c1, c0, 0
2. In a loop, initialize the ~50 MB
3. Disable the Caches, MMU and Program Prediction (It's a constrain from the OS):
mrc p15, 0, r0, c1, c0, 0 bic r0, r0, #ARM_CTRL_ICACHE bic r0, r0, #ARM_CTRL_DCACHEbic r0, r0, #ARM_FLOW_PREDICTbic r0, r0, #ARM_MMU_ENABLE mcr p15, 0, r0, c1, c0, 0
4. Branch to the OS, it will later enable the Caches and MMU again at some point in its initialization sequence.
Is this enough? Or I need to invalidate the caches at any point? Or need to adjust the order of enable/disable.
Thank you.
