I believe that you know such as STM32F103 cpu series support firmware program function by using JTAG with JTAG debugger of keil MDK.
So I want to know does cortexm3 design kit include such as JTAG firmware program function blocks?
What am I supposed to do to implement auch as JTAG firmware program function blocks?
I want to program(write the firmware code) to CM3 with JTAG debugger of keil MDK. Is this possible ?
Yes.
Would you please help me to know how to do that? Please more explain me.
I do not use KEIL, but I am pretty sure their support can help you.
Do you mean flash programming for embedded flash?
Flash memory programming hardware is process vendor specific. So first of all, you need to know which semiconductor foundry you are using, and what type of embedded flash are available. You can then check what type of embedded flash controller IP is available depends on the flash type you selected. The flash controller IP is not inside CM3 DesignStart (due to NDA need for foundry partners).
Once you have the details of the flash controller, then you might need to create flash programming code. This is the part that relate to JTAG. The debugger in Keil MDK download the flash erase and programming code, as well as blocks of program image to SRAM. The programming code is executed and erase the flash, and then the code is executed again (with different parameters) to program the flash, normally page by page. Optionally the flash content is verified after the complete image is programmed.
So the first step to to check what embedded flash technology you are going to use.
regards,
Joseph
Thank you for letting me know that Sir, let me check what embedded flash technology can use.
Yes I meant that it was embedded flash.
I think it would be better going to implement to the FPGA before go to the ASIC,
Then, Is there any best way like to use embedded FLASH (for boot rom) in the FPGA instead using real FLASH?
Probably I can't go with the flash controller IP, Would you please give me some advice? what is the best way to implement the CM3 Design kit to the FPGA without embedded flash ?
Since FPGA do not have real embedded flash, usually we just use SRAM inside the FPGA (block RAM).
You will need an AHB to SRAM wrapper (that should be inside the Cortex-M3 DesignStart bundle) and you can download the code image to the FPGA's SRAM directly (just make sure your project's option remove the flash programming and erase options).
For a simple system, you don't need to have a separated boot ROM. An application image can be placed in address 0 and start from there directly.
Normally embedded flash vendor will provide you with simulation models of embedded flash so that you can test your design.
If you want, you can connect external flash memories to your FPGA design. In that case you might need to design an AHB to external flash interface. But the speed of such external flash access can be a bit slow and the external flash chip interface can be quite different from the interface of an embedded flash. So often this is not the best solution.
Sir, I'm wondering about the speed between "embedded flash" and "external flash memory".
Is there quite of a bit speed difference between "embedded flash" and "external flash memory" ?
Yes, internal flash is usually faster.
Usually external flash use serial interface (i.e. QSPI flash) and hence the access time is longer. But many QSPI interface controller has got some sort of cache to avoid most of the penalty. Some QSPI flash chips can run at 100MHz, but of course, due to serialization it will take a number of clock cycles to read. (https://www.corelis.com/images/screenshots/spi-quadmode-fastread.jpg )
In some of our old FPGA boards we used two 16-bit parallel flash to form a 32-bit flash interface (K8P5615UQA), The access time is 70ns (around 14MHz), but when considering PCB level delay you will likely to get lower speed.
On chip flash speed varies between chip vendors. Most of the low power embedded flash is around 30MHz to 50MHz. But some MCU has embedded flash processes that can run at over 100MHz.
