HI.
I'm trying to understand the relationship between UART and printf within retarget.
as I understand, retarget supports to implement low level function fputc, if I want to use printf().
if I am right, I can't still understand the relationship between printf and UART_STDOUT.
especially, the below example is what I want to share you.
this is the hello.c example code.
//Hello.c #ifdef CORTEX_M3 #include "CMSDK_CM3.h" #else #include "CMSDK_CM4.h" #endif #include <stdio.h> #include "uart_stdout.h" int main(void) { // UART init UartStdOutInit(); printf("Hello world\n"); printf("** TEST PASSED **\n"); // End simulation UartEndSimulation(); return 0; }
and retarget.c
#include <stdio.h> #include <time.h> #include <rt_misc.h> #pragma import(__use_no_semihosting_swi) extern unsigned char UartGetc(void); extern unsigned char UartPutc(unsigned char my_ch); struct __FILE { int handle; /* Add whatever you need here */ }; FILE __stdout; FILE __stdin; int fputc(int ch, FILE *f) { return (UartPutc(ch)); } int fgetc(FILE *f) { return (UartPutc(UartGetc())); } int ferror(FILE *f) { /* Your implementation of ferror */ return EOF; } void _ttywrch(int ch) { UartPutc (ch); } void _sys_exit(int return_code) { label: goto label; /* endless loop */ }
I can't understand how does printf() work? Is printf() working as UART function as a fake ? or really works as UART?
Is printf() connected UART function? I can't understand the relationship between UART function of cortex-m3 and printf().
Does printf() differently work such as printf() of ANCI C?
Would you please anyone help me to understand this question to clarify?
Thanks in advance
