Replacing branch-instruction with address assignment to PC
in a thumb-assembly file (my toolchain is gcc 4.8), I want to replace a branch with address assignment to the program-counter.
So instead of:
b   lbl
I want to have something like:
pc = address(lbl)
This solution works. Here, I use the following code to store the address of a label in a register (here r12) and assign this to the pc.
But when I, as shown below, use the stack to restore the value of r12 the execution crashes:
If I, as you can see below, first store the address from the stack in the r12 and then move it to pc the code runs without any problem.
any ideas what could be the reason why in pop {pc} (in the second code-segment) doesn't work?
PS. The code is being executed on a Cortex-M4F
0
