Is any synchronization barrier instruction necessary after writing SPSel to switch to SP0 on armv8?
Hi Fellows,
I want to switch stack pointer to SP0 from SP1 every time an exception is taken to EL1 on armv8. I execute MSR  SPSel, #0 to do this. My question is that is it necessary to use an ISB intruction etc. after it? If yes, what are the performance overheads if any? The reference manual does say the following:
"Changing PSTATE.SPSel to use EL0 synchronizes any updates to SP_EL0 that have been written by an MSR to SP_EL0, without the need for additional synchronization."
But I am not sure it concerns my question. Thanks.
Best Regards,
Mughees
  • Hi,
    The line you quote deals with synchronization between writes to SP_EL0 and making it active, so solves half the problem.  It means that:
    MSR SP_EL0, x0
    MSR SPSel, #0
    Doesn't need any extra barriers.
    The other interesting part in the spec is:
    "Writes to the PSTATE fields have side-effects on various aspects of the PE operation. All of these side-effects are
    guaranteed:
    • Not to be visible to earlier instructions in the execution stream.
    • To be visible to later instructions in the execution stream."
    Which deals with when you can guarantee which SP is used.:
    MSR SPSel, #0
    STP x3, x4, [sp] // SP is now SP_EL0
    Pete.
  • Thanks Pete. That helps a lot.
