VTTBR_EL2 alignment
Hi folks,
in Armv8 reference manual, in the description of the VTTBR_EL2 register, the BADDR fields seems to have alignment constraints:
Translation table base address, bits[47:x]. Bits [x-1:0] are RES 0.
The AArch64 Virtual Memory System Architecture chapter describes how x is calculated based on
the value of VTCR_EL2.T0SZ, the stage of translation, and the translation granule size.
However I'm a bit confused here. There are several computations of such an `x`, with no clear reference of the current scenario for each computation.
In Armv7 reference manual, the computation for this `x` was always clear for TTBR0, TTBR1, HTTBR, ...
In v8, I don't see any clear reference to the correct computation.
Where can I find the correct value of x for a aarch64 EL2 software, depending of level lookup, granule size and T0SZ ?
Best,
V.
Bonus question: I realise that the information is also hard to find for others TTBR, where I can I find each computation ?
0
