Hi all,
I am trying to connect to the RPi2 JTAG.
I have the following setup
- Raspberry Pi 2 running Raspbian 8.0 (Jessie)
- OpenOCD 0.9.0 with a J-Link EDU connected to a Ubuntu system.
I setup the GPIO in order to expose the JTAG interface and the JTAG connection works: I can halt/resume processors.
The issues start whenever I tried to access the memory (with the CPU halted).
For example
> halt ttbcr 0ttbr0 378a806attbr1 406arpi2.cpu.3 rev 5, partnum c07, arch f, variant 0, implementor 41number of cache level 2cache l2 present :not supportedrpi2.cpu.3 cluster f core 3 multi coretarget state: haltedtarget halted in ARM state due to debug-request, current mode: Supervisorcpsr: 0x60000093 pc: 0x80021868MMU: enabled, D-Cache: enabled, I-Cache: enabled> dump_image ram.bin 0x08000 0x1000timeout waiting for DSCR bit changein procedure 'cache_config'
Is there anyone aware of this issue?
Is there anything I can do to dig into the problem? I was thinking about disabling the cache...
Any help would be appreciated.
Best
Alex
Could it be related to some cache coherence issue?
I was able to access the memory via JTAG by using a bare metal firmware on the Raspberry (no OS) which does nothing but configure the JTAG on the GPIO.
Here the only notable difference is that the 1st level cache and MMU are disabled.
Thanks for any hint.
