Hello All,
I am integrating CAN stack, on Spansion S6J3xx series.
I have configured Main clock as Input frequency, configured CAN transceiver IC and called CclPowerOnInit().
Now calling CanTransmit(X_TxHandle), function in a 100ms task, but still no signal is coming on TX and RX pin.
Anyone can suppport me?
I have no experience on how the CAN driver needs to be configured on a Cortex-R device, but I have worked with Cortex-M and I'd like to mention a few things that might help you getting the problem solved:
As I expect CclPowerOnInit() will enable clock-power for the CAN interface, I will move the focus elsewhere.
Since the transmit function does not output any data on the expected pin, I would expect that the problem has to do with pin configuration somehow.
I wouldn't be surprised if other members of the community are able to provide much better answers than I.
(If we're lucky, jyiu, christopherseidl or mweidmann might see this question too).
