I am looking for ECC insertion method (any instruction) on any address with ARM Cortex M4. Some processors sport data line flips using instructions.
Hi anujhp, welcome to the Community!
I have moved your question to ARM Processors where I think an expert can help.
do you want to design an MCU based on Cortex-M4?
If it is right, you can equip ECC logic outside of ICode AHB-Lite instruction interface?
If you are looking for such MCUs, as far as know, there would be no such MCU of which ECC covered the all instruction address space.
However, regarding Flash space, almost all MCUs have the flush cache to buffer differences between CPU and Flash access time.
The flash cache would be always ECC protected.
Best regrads,
Yasuhiko Koumoto.
Hello Yasuhiko Koumoto,
Thanks for your answer.
As of now I am looking for SRAM validation. SRAM supports ECC feature, Now I want to insert ECC error on address space of sram.
If there is any instruction or way to insert ECC error on some address(For testing purpose) then it will be very helpful.
Best Regards,
Anuj
Hello Anuj,
do you want to validate by RTL or Gate Level?
Or a real chip level?
If you are saying about a real chip validation, it is impossible to insert ECC error unless the chip has such the feature as hardware.
Best regards,
Thanks for your reply.
I am looking for chip level, when there is no method available for ecc insertion.
I have one idea:
Don' initialize one section of SRAM and try to read that area, might be we can hit single bit or double bit ecc error at some random location in uninitialized area.
But this will not give proper control.
