ARM Cortex A9 second execution unit
Dear All,
I am trying to understand the full working of execution stage in ARM cortex A9 and the types of instructions that are executed in second execution unit(ALU).
Till now i was able to find quite limited references that were not much helpful.
If any of you know anything related to execution in "Second execution unit of ARM cortex A9" or any related references, please let me know!!
Also it is possible to discuss further here in the forum directly. Looking forward to your input.
Thanks & regards.
  • Kushal,
    You could start with asking a question. What exactly do you want to know? (And how do you expect to use this knowledge).
    I've not worked with Cortex-A9 in particular but as far as I can see from its datasheet - you are asking about very internal things, the knowledge of which is probably of very little use for most developers.
  • Indeed, your questions about are about detailed internals which are not usually useful to software developers. In general, if the information you are looking for is not in the Cortex-A9 Technical Reference Manual (have you looked at that yet?), then it should be regarded as confidential and ARM will not usually disclose it.
    But, please do ask specific questions and, wherever possible, we will do our best to answer them.
    Regards
    Chris
  • Thankyou so much for the reply....
    I'll try to explain the best I know.
    Cortex A9 is a dual issue, superscalar processor.
    Dual issue means 2 instructions can be executed at a time simultaneously.  Execution unit itself has two ALU pipelines which can run simultaneously and execute instructions.
    Both of them are named as main pipeline and secondary pipeline.  As far as I understand, both these pipeline executes data processing instructions but higher priority is for main pipeline. Please correct me if my understanding is wrong!!!
    Thankyou
  • You are basically correct. Yes, there are two ALU back-end pipelines, following a common front-end. The front end pipeline consists of 6 stages, handling pre-fetch (three stages), instruction queue, decode and register rename. There are a total of four back-end pipelines. Two are ALU execution pipes, both capable of handling any ALU instruction. One is capable of also handling MAC instructions. The remaining two are a Load/store pipeline and a separate pipeline for the NEON/Float compute engine.
    That much you can learn by attending one our excellent training courses! We don't generally disclose any more detailed information than that.
    May I ask why you are interested in the pipeline structure? Are you trying to solve a particular optimization problem?
    Chris
  • Thank you so much sir...that was quite helpful.
    Big fan of your videos on youtube!!
    I am just a student who is using Zynq 7000 SoC platform for embedded systems studies.
    I was using PMU to analyze the kernel and user activity over linux running on Microzed development board!!
  • You're most welcome. I'm glad you found that helpful. The Zynq is an excellent platform for system exploration.
    Always nice to hear that the videos are useful!
    Best wishes
    Chris
