Basically I want to provide delay of 15 clock cycles for writing and reading through axi4 bus .Is it possible?
Sir
The write is still not working.
i have a doubt. According to the timing you have assumed it states that during a write transaction the wvalid will be asserted after awready.
But in the manual ambaaxi it has been quoted that "
It is important that during a write transaction, a master must not wait for AWREADY
to be asserted before driving WVALID. This could cause a deadlock condition if the
slave is conversely waiting for WVALID before asserting AWREADY.
Then the logic would fade.
Regards
Preet Kaur Walia
Hello Preet Kaur Walia.
I am sorry. I forget the current First_WDATA_Mask would be too late to stop the first data cycle.
I think that if the reset value of First_WDATA_Mask was '1' and it would become '1' at every writing done (BVALID&BREADY), it might go well.
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; else if(BREADY&BVALID) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE&WVALID&WREADY) FIRST_WDATA_MASK <= 0; end
Best regards,
Yasuhiko Koumoto.
I have done the following change to the code and it seems to work.
As we donot know that awready will be high before or after wvalid. Therefore there is possibility that first data mask will remain 1 as this condirion may not get true
the changed code
regards
I doubt your suspicion (or maybe experiment result?) "if(WADDR_DONE&WVALID&WREADY)" might not become true because WVALID and WREADY should independent according to "A3.3.1 Dependencies between channel handshake signals" of AXI specs.
Actually, there would be some wrong scenarios with your implementation of "else if(WADDR_DONE & WREADY)" and the reset value was '0'.
If First_WDATA_Mask reset value was '0', it cannot handle the following scenario.
I think almost all case would be the <2> timing.
And "else if(WADDR_DONE & WREADY)" would not handle the following scenario.
This would be the same situation with "else if(WADDR_DONE & WVALID)".
So, I would like to propose the following description.
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; // new change else if(AWVALID & masked_AWREADY) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & WREADY & WVALID) // should not change FIRST_WDATA_MASK <= 0; end
How about this?
Otherwize.
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; // new change else if(AWVALID & masked_AWREADY) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & (wcount==4'hf)) // new change FIRST_WDATA_MASK <= 0; end
None of the solutions seem to work and I am not able to figure out the reason.
Hello Preet Kaur Walia,
it's sad news.By the way, you said that if the following logic was used, it went well.
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 0; else if(AWVALID & masked_AWREADY) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & WREADY) //change FIRST_WDATA_MASK <= 0; end
If it is correct, I guess that your master would not assert WVALID until getting WREADY from the slave. But it would violate the AXI specs.Can you confirm it?If you can confirm it, I should compromise the description above.To the contrary, if your slave would not assert WREADY until getting WVALID from the master, "else if(WADDR_DONE & WREADY)" would be replaced for "else if(WADDR_DONE & WVALID)".
By the way, I have found something was wrong."else if(AWVALID&masked_AWREADY)" would be strange (also in the read case).I'm sorry but I think masked_AWREADY should be AWREADY.
I am afraind WADDR_DONE would not become "1" with the previous description.Therefore, the logics would be the following.
always@(posedge CLK) begin if(~ARESETN) WADDR_DONE <= 0; else if(AWVALID&AWREADY) WADDR_DONE <= 1; else if(BVALID&BREADY) WADDR_DONE <= 0; end always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; else if(AWVALID&AWREADY) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE&(wcounter==4'hf)) FIRST_WDATA_MASK <= 0; end always@(posedge CLK) begin if(~ARESETN) wcounter <= 4'h0; else if(WADDR_DONE&masked_WVALID&masked_WREADY) wcounter <= 4'hf; else if(wcounter!=4'h0) wcoubter <= wcounter -1 ; end assign mask_pre = (wcouner != 4'h0); assign WREADY_mask = FIRST_WDATA_MASK | mask_pre; // CHANGE! assign WVALID_mask = mask_pre; // CHANGE! assign masked_WVALID = WVALID & ~WVALID_mask; // RVALID for master assign masked_WREADY = WREADY & ~WREADY_mask; // RREADY for slave assign masked_AWREADY = ~WADDR_DONE & AWREADY; // this make outstanding 1
How about them?I'm sorry for you inconvenience.
can you tell me the status of your work?Was your problem solved?If you have already solved it, please let me know your methods.
Sorry for the delay. I was out of station and could not work on the problem further. I will start with it today again and will update you shortly.
The condition
if(~ARESETN)
end
should work fine considering that wvalid and wready need not be high together. Therefore, it might be possible that wvalid has gone high for a clock cycle and aftersometime wready goes high. Data mask should go low after that. Therefore it would not deviate from the AXI specification.
if the releasing the FIRST_WDATA_MASK only by WREADY made your system working fine, it's a good news.I think the characteristic of "wvalid has gone high for a clock cycle and aftersometime wready goes high" would be strange because the assertions (i.e. go to High) WVALID and WREADY should be independent.If the master makes WVALID high before the slave makes WREADY high, the FIRST_WDATA_MASK logic cannot stop the data cycle.The logic will only go well if the WVAID of the master will go high after the slave would make WREADY high.Anyway, there would be the timing WVALID and WREADY will be High at the same and I wonder why "WADDR_DONE & WVALID & WREADY" would be wrong for de-asserting FIRST_WDATA_MASK.The only possibility would be WADDR_DONE was '0' at the timing when "WVALID & WREADY" was '1'. These are the cases <1> and <2> of my previous post.I will propose the new condition for releasing FIRST_WDATA_MASK.Could you please try it?
always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; // new change else if(AWVALID & AWREADY) FIRST_WDATA_MASK <= ~(WVALID & WREADY); else if(WADDR_DONE & WVALID & WREADY) FIRST_WDATA_MASK <= 0; end
Best regards,Yauhiko Koumoto.
I am working on it. Also I had a query that in the write case ,
According to me the following scenario should be followed:
We should mask wvalid as we need to stop the wvalid from the CPU from going to the slave otherwise, it will do the write transaction as and when wvalid is high.Slave will then send wready (telling the CPU it is ready to accept more data).
Whereas we are working on the contrary. As it can be seen from the first data mask situation, wready is being masked and wvalid is being sent to the slave. Therefore, there is a possibilty that slave has already written the data to memory before we are providing the delay. (in the first data mask situation we are only masking the wready)
This is not right. It has possibility of deadlock. The wvalid and wready should be independent.
No, we consider two cases which wvalid is faster than wready and wready is faster than wvalid.
I'm sorry. You are right.assign WVALID_mask = mask_pre;would be alsoassign WVALID_mask = FIRST_WDATA_MASK | mask_pre;
It does not work .
Preet
I am very sorry for your inconvenience.
I have debugged and verified the codes on a real simulation environment.
I have observed that they had went very well,
I hope this will help you.
module AXI_W_DELAY15( CLK, ARESETN, AWVALID, // from a master AWREADY, // from a slave WVALID, // from a master WREADY, // from a slave BVALID, // from a slave BREADY, // from a master WLAST, // from a master masked_WVALID, // to a slave masked_WREADY, // to a master masked_AWREADY // to a master ); input CLK; input ARESETN; input AWVALID; input AWREADY; input WVALID; input WREADY; input BVALID; input BREADY; input WLAST; output masked_WVALID; output masked_WREADY; output masked_AWREADY; reg WADDR_DONE; reg FIRST_WDATA_MASK; reg [3:0] wcounter; wire mask_pre; wire WREADY_mask; wire WVALID_mask; always@(posedge CLK) begin if(~ARESETN) WADDR_DONE <= 0; else if(~WADDR_DONE & AWVALID & AWREADY) WADDR_DONE <= 1; else if(BVALID & BREADY) WADDR_DONE <= 0; end always@(posedge CLK) begin if(~ARESETN) FIRST_WDATA_MASK <= 1; else if(WADDR_DONE & (wcounter==4'hf)) FIRST_WDATA_MASK <= 0; else if(wcounter==4'h0) FIRST_WDATA_MASK <= 1; end always@(posedge CLK) begin if(~ARESETN) wcounter <= 4'h0; else if(wcounter!=4'h0) wcounter <= wcounter -1 ; else if(WADDR_DONE & WVALID & WREADY & ~(WLAST & masked_WREADY)) //!! wcounter <= 4'hf; end assign mask_pre = (wcounter != 4'h0); assign WREADY_mask = FIRST_WDATA_MASK | mask_pre; assign WVALID_mask = FIRST_WDATA_MASK | mask_pre; assign masked_WVALID = WVALID & ~WVALID_mask; // WVALID for master assign masked_WREADY = WREADY & ~WREADY_mask; // WREADY for slave assign masked_AWREADY = ~WADDR_DONE & AWREADY; // this make outstanding 1 endmodule module AXI_R_DELAY15( CLK, ARESETN, ARVALID, // from a master ARREADY, // from a slave RVALID, // from a slave RREADY, // from a master RLAST, // from a master masked_RVALID, // to a master masked_RREADY, // to a slave masked_ARVALID,// to a slave masked_ARREADY // to a master ); input CLK; input ARESETN; input ARVALID; input ARREADY; input RVALID; input RREADY; input RLAST; output masked_RVALID; output masked_RREADY; output masked_ARVALID; output masked_ARREADY; reg RADDR_DONE; reg FIRST_RDATA_MASK; reg [3:0] rcounter; reg next_rlast; reg next2_rlast; reg RVALID_delay; reg done_raddr; wire rmask_pre; wire RREADY_mask; wire RVALID_mask; always@(posedge CLK) begin if(~ARESETN) begin next_rlast <= 0; next2_rlast <= 0; done_raddr <= 0; end else begin next_rlast <= (rcounter == 4'h1); next2_rlast <= next_rlast; done_raddr <= RLAST & masked_RREADY; end end always@(posedge CLK) begin if(~ARESETN) RADDR_DONE <= 0; else if(~RADDR_DONE & ARVALID & masked_ARREADY) RADDR_DONE <= 1; else if(done_raddr & (next2_rlast & ~(RVALID & ARVALID & ARREADY))) //!!! RADDR_DONE <= 0; end always@(posedge CLK) begin if(~ARESETN) FIRST_RDATA_MASK <= 0; else if(ARVALID & masked_ARREADY) FIRST_RDATA_MASK <= 1; else if(rcounter==4'hf) FIRST_RDATA_MASK <= 0; end always@(posedge CLK) begin if(~ARESETN) rcounter <= 4'h0; else if(rcounter!=4'h0) rcounter <= rcounter -1 ; else if(RADDR_DONE & RVALID & RREADY & ~next_rlast) //!! rcounter <= 4'hf; end assign rmask_pre = (rcounter != 4'h0); assign RREADY_mask = FIRST_RDATA_MASK | rmask_pre | next2_rlast; assign RVALID_mask = FIRST_RDATA_MASK | rmask_pre | next2_rlast; assign masked_RVALID = RVALID & ~RVALID_mask; // WVALID for master assign masked_RREADY = RREADY & ~RREADY_mask; // WREADY for slave assign masked_ARREADY = ~RADDR_DONE & ARREADY; // this make outstanding 1 assign masked_ARVALID = ~RADDR_DONE & ARVALID; // this make outstanding 1 endmodule
The write does not seem to work for me. Which environment have you used? I have not tried read yet.
