Hi
i have some questions on dual Core CortexA9 r3p0 revision.
I am using Cortex A9 r3p0 processor in Our SOC(system on Chip). when i connect to Core 0 and read TTBR0 register i get 0x00004001, but when i connect to Core1 and do read the same TTBR0 register, i get 0x4f352089. is it Okay getting different value.
when i change TTBR0 register value in core 0 , and disconnect to core 0 and again connect to it by soft reset, my changed value disappears and i again get 0x00004001, but same not happens with Core1. in Core 1, say, i change TTBR0 from 0x4f352089 to 0x1
and by disconnecting and again connecting through soft reset, i get changed value means 0x1, not 0x4f352089. what does it mean?
Hello anoopstm,
It is Okay because core 0 and core 1 are independent.
I think the TTBR0 initial value would be undefined by the reset.
I guess you are doing the test under execution of the core 0 and the modified value of TTBR0 would be recovered by OS.
Best regards,
Yasuhiko Koumoto.
Also TTBR0 is security banked so depending when you stop the core in the boot process you may be reading a different register.
i am not executing any boot code or Operating system. just i am connecting gdb after power on reset.
did you check the gdb had not set the TTBR0?
