Which bit of WSTB should be set to 1?
I have one question.
If the data bus width of the AXI bus is 16 bytes, and a Write Burst transfer is performed with start address = 0x1008, LEN = 0, and SIZE = 0, which bit of WSTB[15:0] should be set to 1?
Could you please answer to this question ?
  • Hi, this would be as follows
    Byte 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0
    WSTRB 0 0 0 0 0 0 0 1 / 0 0 0 0 0 0 0 0 0
    The transaction container is calculated using:
    Container_Size = Size * Length = 1 byte
    Inside of the transaction container any number of write strobes can be HIGH. This effectively maps to byte lane 8 only.
    Outside of the transaction container all write strobes must be LOW. This effectively maps to all byte lanes, expect for byte lane 8.
    Hope that helps.
    Kind regards,
    Ben
