timing diagram
Hi All,
Is there any CHI timing diagram ? I can not find it in the spec
Tom
  • Hi Tom,
    Most of CHI is documented with Time-Space and transaction flow diagrams rather than classic waveform timing plots, due to the nature of abstraction between the transport layer and the protocol layer.
    If you look at Figure B14.1 in CHI-G.b (available here) then you can essentially equate the flit transfer on clock edge 3 as a protocol packet being transferred. If you then look at section B2.3 (Transaction structure), and consider one of the transaction flow diagrams such as Figure B2.3 (Immediate Write) then each of the narrow arrows is essentially a protocol message that is being sent using a single packet/flit. The thicker arrows are on the DAT channels, and represent instances where protocol messages might use multiple packets/flits to communicate, due to the transaction Size and the channel Data_Width.
    Kind regards,
    Ben
  • Hi Ben,
    In this figure, I am bit confused. For example: when HN receive read shared operation, HN can send comp data next cycle or next few cycles in the figure? I wonder RN send operation to HN, then RN can receive response next cycle? thank you
  • In that example, the earliest the HN could provide CompData (or any other response) is the next cycle. However, in practice, that is highly unlikely. Home components are complicated blocks that will have a range of control (and most likely storage logic). You'd expect the incoming request to cause a look up of some kind in a local cache, which will take a few cycles at least. It is more likely that a response will be given a number of cycles later
