ARM v8 SMMU Stage 2 translation fails
Working on a SoC with MMU_600. There is a baremetal code which runs in EL3. SMMU is configured for stage 1 and stage 2 translation, VA to PA is one to one mapping.
Configuring Stage 1 only works fine for 4K granule, but when stage 1 and stage 2 are enabled stage 2 fails with a translation fault.
Does EL3 support stage 2 translation ? or any suggestions on configurations.
Thank you,
code snippet Stage 2 config:
S2VMID = sid;
S2T0SZ = TTBCR_T0SZ(40); // (64 - 40)
S2SL0 = STE_S2SL0_4KBTG0_L1_16_64KBTG0_L2; // 1
S2IR0 = STE_S2IR0_WBC_RA_WA; // 1
S2OR0 = STE_S2OR0_WBC_RA_WA; // 1
S2SH0 = STE_S2SH0_IS; // 3
S2TG = granul_size; // 0 == 4K
S2PS = STE_S2PS_40b; // 2
S2AA64 = STE_S2AA64_AARCH64; // 1
S2ENDI = STE_S2ENDI_LE; 0
S2AFFD = STE_S2AFFD_NOFLT; // 1
S2R = 1;
  • Hi ,
    EL3 has only stage 1 translation (TTBR0_EL3); see this page for a diagram.
    Note that EL3 uses the MMU for its translations, while devices use the SMMU.
    In the case of a fault, the SMMU will report a translation fault Event record in the Event queue.
    The S2 field (bit 103) of the F_TRANSLATION Event record will let you confirm the stage at which the fault happened.
  • Thank you  ,
    My understanding was SMMU stage-2 translation is independent of CPU EL.
    Conclusion is stage 2 translation for MMU/SMMU will only work in EL2. Can you please confirm
  • Update:
    For 64K granule there is no translation fault when both stage 1 and stage 2 are enabled.
    For 4K and 16K granule I am observing the translation fault in stage2.
  • Hi ,
    This is correct.
    For the MMU of the CPU, the EL2 configures the stage-2 translation (VTTBR0_EL2), which applies to EL1 and EL0.
    For the SMMU of the devices, software running on the CPU configures stage-2 translation (STE, CD...). This is not directly related with the CPU EL.
  • Hi  ,
    I am configuring SMMU for stage1 and stage 2 translation, not sure which configuration I have missed.
    For 4K granule I am getting stage 2 translation fault, can you provide proper configurations
  • Does EL3 support stage 2 translation ? or any suggestions on configurations.
    There's a subtly here.
    In the CPU architecture, the EL3 translation regime only has S1 translation - not S2.
    In the SMMUv3 architecture, in the Stream Table Entry you have to specify the StreamWorld.  Broadly, these controls which CPU architecture translation regime you want to replicate.  If the StreamWorld is set to EL3 (assuming your SMMU supports it), then the SMMU doesn't support S2 for that Stream.
    Have you checked the F_TRANSLATION record, what does it report?
  • STRW of stream table entry is set to NS-E1.
    F_Translation capture,
    0x7e000000 0x10
    0x7e000004 0x11
    0x7e000008 0x0
    0x7e00000c 0x280
