Description:
I'm using FVP + boot-wrapper-aarch64 to boot a Linux kernel. When running with a single core, the boot process is successful. However, when enabling multiple cores, the boot fails.
Observations:
In boot-wrapper-aarch64/common/init.c, it appears that only the primary CPU (CPU 0) executes the boot function:
```c
void cpu_init_bootwrapper(void){ static volatile unsigned int cpu_next = 0; unsigned int cpu = this_cpu_logical_id();
if (cpu == 0) init_bootwrapper();
while (cpu_next != cpu) wfe();
cpu_init_self(cpu);
cpu_next = cpu + 1; dsb(sy); sev();
if (cpu != 0) return;
while (cpu_next != NR_CPUS) wfe();
print_string("All CPUs initialized. Entering kernel...\r\n\r\n");}
Possible causes:
sev()
Additional Information:
Further questions:
Any insights or debugging methods would be appreciated!
