TCMRETRY
I would like to use the TCMRETRY function of your company's ARMV7 chip, but there is little and unclear description of this function in the documentation, so I would like to seek assistance.
May I ask how to use this feature and how to implement it specifically?
  • TCMRETRY relates to when TCMs are implemented with Error correction (ECC).
    There is some example code (for Cortex-M7) on how to initialize here:
    https://developer.arm.com/documentation/ddi0489/f/initialization/about-initialization/enabling-the-tcm-retry-and-read-modify-write
    If you need further information, I would suggest raising an official support case from the menu above.
  • Hello, maybe I didn't express myself clearly.
    What I mean is that I understand the function of this signal, but in actual chip hardware design, how should this signal be coordinated with external ECC.
    For example, when I detect that the ECC check of the read data returned by TCM at address 0x010 fails, I will raise the TCMretry signal.
    What I want to know is how the core will react when it receives the TCMretry signal at this time. Will Core re initiate access to address 0x10?
    Also, if the access request to TCM is an instruction received by an external AHBS port, is the RDATA returned by AHBS incorrect data or the data obtained after the core re initiates the access?
    If possible, could you provide a detailed timing diagram for this function, as the manual only covers how to reverse the signal timing diagram, and does not introduce the response of the core after reversing the error
  • Hi Delia,
        In my system , TCM ECC has been used.
        "The typical use of the *TCMRETRY signal is that a read transaction is retried when an TCM ECC error is detected and the error is corrected. Retrying the read transaction can get the correct read value later.​"
    ---------------In my system ,when I find ECC error, I will set TCMRETRY ​to High. but AHBS bus interface stll return error rdata,
    Can you provide a simulation waveform test case for the use of TCMRETRY?
    When should I raise the TCMRETRY signal and return the correct RData data when I discover an ECC error?
    How to handle when the core receives a high TCMRETRY signal?
    Best friends,
    depei
