Cortex A9 Boot operation Sequence
We're developing a proprietary RTOS using several of the cores in a Cortex A9MP processor. We've already run the OS on a single core, and now want to add additional cores. My main question is concerning the cache and MMU initialization for the primary core vs the secondary cores. The sequence for the primary core is:
  1. Initialization of memory and stacks
  2. Initialize the GICD and GICC
  3. Disable L2 cache
  4. Invalidate L1 dcache
  5. Invalidate L1 icache
  6. Invalidate the TLB
  7. Enable dcache prefetch
  8. Enable branch prediction
  9. Allocate memory for the MMU table
  10. Write the address of the MMU table into TTBR0
  11. Create the basic entries in the MMU table
  12. Set client mode for all domains (DACR)
  13. Set SMP bit
  14. Enable the SCU
  15. DSB
  16. ISB
  17. Enable the dcache
  18. Enable the L2 cache
  19. Enable the icache
  20. Enable the MMU in sctlr
This is the basic sequence. After this, core 0 is up and running with both L1 and L2 caches enabled. So my question is can I now enable core 1 with the L2 cache enabled, or do I need to bring it up and functional, and then enable the L2 cache? The MMU is set up with flat mapping, and the memory space for each additional core is set to shared so that core 0 can write the OS into it. Each core has the SMP bit set. The MMU table is accessible to all the cores.
  • To further clarify, the question is when is it safe to enable the L2c310 level 2 cache. Do I have to wait until all of the secondary cores are initialized or is it OK to let the primary core enable the L2c310 THEN enable the secondary cores?
