What is the appropriate way to load and store data for the recent Arm Neon MMLA instructions?
For example, the description of SMMLA is:
> Signed 8-bit integer matrix multiply-accumulate. This instruction multiplies the 2x8 matrix of signed 8-bit integer values in the first source vector by the 8x2 matrix of signed 8-bit integer values in the second source vector. The resulting 2x2 32-bit integer matrix [...]
They require inputs sized 2x8 and 8x2 and produce outputs of the form 2x2. How can I efficiently load and store data for these functions? With matrices that are either row- or column-major, I see three broad possibilities to use these instructions, none appealing:
An example code for the inner loop (reduction over K) of a small 4xK input matrix A (row-major) and a Kx4 matrix B (column-major) is as follows (loading 64-bit vectors and combining them):
for (size_t k = 0; k < 64; k += 8) {
uint8x8_t low = vld1_u8(row0);
uint8x8_t high = vld1_u8(row1);
uint8x16_t row01x01234567 = vcombine_u8(low, high);
row0 += 8;
row1 += 8;
low = vld1_u8(row2);
high = vld1_u8(row3);
uint8x16_t row23x01234567 = vcombine_u8(low, high);
row2 += 8;
row3 += 8;
low = vld1_u8(col0);
high = vld1_u8(col1);
uint8x16_t col01x01234567 = vcombine_u8(low, high);
col0 += 8;
col1 += 8;
low = vld1_u8(col2);
high = vld1_u8(col3);
uint8x16_t col23x01234567 = vcombine_u8(low, high);
col2 += 8;
col3 += 8;
out01x01 = vmmlaq_u32(out01x01, row01x01234567, col01x01234567);
out01x23 = vmmlaq_u32(out01x23, row01x01234567, col23x01234567);
out23x01 = vmmlaq_u32(out23x01, row23x01234567, col01x01234567);
out23x23 = vmmlaq_u32(out23x23, row23x01234567, col23x01234567);
The result is correct, but seems terribly inefficient. The code above is just an example. I actually would use larger tile sizes to maximize register usage.
