I'm trying to perform a 64 bit write access to a certain memory (data access) located in the peripheral area using the M55 AXI bus.
I see the disassembly and it looks ok ("strd" command).
however, in the waves, I see that the M55 exported 2 AXI operation . each one is 32 bits width.
is there a way to configure it to export it with a single 64 bit operation instead of two 32 bits operations?
note that fetch access does generate a AXI 64 bit transaction . looks like it only related to data access.
