Hello all,
We have a specific case that we need to return to a NSCallable section, and we need to call/jump a Callback that points a function in Non-Secure World.
When we try this, we are getting SFSR->INVTRAN (Secure Fault: Invalid transaction) exception.
Is there any architectural limitation or can we perform this somehow?
Thank you.
Hi
My name is Sally and I work at Arm.
When calling non-secure code from secure code, secure code must call non-secure code using an interstating branch instruction: BXNS or BLXNS
Attempting to switch to Non-secure state via any other branch will result in:
I think you may have encountered the situation I described. You can check it out, or describe the scenario of your case and the instructions used in more detail.
Hope this helps.
Best Regards,
Sally
