I have an Xilinx Ultrascale+ device and wish to test whether the L1 Data cache has bit errors.
Would the following ideas be feasible?
// Idea 1: L1D data read and write. // 0) In a baremetal helloworld app, Disable/enable/flush Dcache // 1) Write DDR Range 1 with known data (maybe increment from 0 upwards). // 2) Read Range 1 addresses, force caching and fill the entire L1D. // 2.1) Compare with expected value for errors. // 2.2) HW m/AXI may pass 64b data to register without going thru L1D? // 3) Invert all the data and write back to those addresses. // 3.1) Data in L1D is updated (A53 seems to use writeback policy). // 4) Read another chunk of DDR, force L1D to evict and write back. // 5) Read back DDR Range 1 via jtag, compare with expected data.
// Idea 2: Use CPUMERRSR.RAM_address[11:0]. // 0) In a baremetal helloworld app, Disable/enable/flush Dcache // 1) Do some ld/st in 1 address of the L1D. // 2) Check CPUMERRSR for error and whether the RAM_address is updated. // 3) Iterate through 1/2 until all L1D is tested. // 3.1) Can only locate CPUID/Way, not exact bit.
If the objective is to test the ECC of the L1D, besides register "CPUMERRSR_EL1", which is a summary of all bits.
Is it possible to test how many bits which may contribute to
I am aware of A53RTM: 6.7 Direct access to internal memory, but I am not sure whether it's implemented in the device itself.
Thank you.
User_0182
