Hi all,
I expect to disable alignment check on Cortex-A53 processor but a misaligned access to normal memory by STR instruction still causes an alignment fault data abort exception.
The processor runs an OS in EL1 that is using non-secure AArch32 and SCTLR.A has been set to 0 already but it didn't work.
According to Arm Architecture Reference Manual for A-Profile architecture E2.6.2 Unaligned Data access, an unaligned access by LDR/STR instruction seems to be permitted.
My test code looks like the following:
uint8_t *buf = malloc(5); // buf is word aligned buf++; // make buf unaligned *(uint32_t *)buf = 0; // alignment fault. Assembler code is like STR R3, [R4,#1]
What could be the possible reason of this alignment fault?
Thanks for all replies.
The problem is solved when MMU is enable.
