IERRR bit set before GIC initalisation
Hi ,
In our system, check all IERRR bits before GIC initialization. In one board, we found one ierrr bit set always. Every time same ierrr bit set
1) What will be the possible root cause of the IERRR bit set?
2) Is it related to SPI SRAM voltage or current or frequency issue?
3) is it SPI SRAM hardware defective?
Note:
After GIC init also checks IERRR bit, still IERRR bit is set
Please help to find the answer. Waiting for reply
0
