Hi Experts,
I was going through the arm v8 mmu page table formation, when it's compared to arm v7 it is completely different.
I could see how to set the different page attributes like caching policies, but I couldn't get how to mark a page as shareable to enable the exclusive load store instructions.
can you please help me with correct location where we can set the shareable attribute ?
The sharabilty is set in the descriptor in the AArch64 translation tables, it is controlled by a combination of the lower attributes and the memory type. Device and non-cacheable memory is treated as being outer shareable.
For normal cacheable memory; in the lower attributes of the block descriptor you have a 2 bit shareability field SH[1:0]:
00 Non-shareable
01 UNPREDICTABLE
10 Outer Shareable
11 Inner Shareable
SH is bits [9:8] of the descriptor.
thank you Peterrielly.
