My Controller is NXP MKE04Z128VLH4 with ARM Cortex M0+ where I have initialised two timer interrupt one is 625 us and the next is 1 ms.And when I'm observing the 625 us timer interrupt by toggling a GPIO Pin and using DSO, I'm observing flucatuation but at the same time if I'm disabling 1 ms timer interupt ,625us interupt is not showing any fluctatuation. I have tried assigning priority to both as 1 and 0 using NVICSetPriority but still issue not got solved.Is this an effect of Interrupt Latency and can it be solved by tail chaining. If yes how to implement Tail Chaining?
